Samsung Galaxy Note 20 Ultra Mobile Network Problem
(Topic created on: 11-22-2024 06:30 AM)
Millz1
Galaxy Note
My galaxy note 20 Ultra has lost moble network. I have tried to insert a different simcard but to no avail. I have also tried to factory reset it but still no mobile network.
As you can see,flight mode is auto enabled and it wont turn off. How can I fix this problem?
15 Comments
Millz1
Galaxy Note
I tried all this even factory reset but to no avail
Galaxy Note
When did this error happen ? ,was it after a security update
Millz1
Galaxy Note
It was just random. I just woke up to a phone without mobile network connection. The only incident I can remember was that it dropped in water in a about a month ago but it was working just fine afterwards until just now
Galaxy Note
If you go to your settings > connections> sim manager , are your lines activated ,, kindly share that option 1732304160620.jpg
Millz1
Galaxy Note
It does not have Sim manager because it's a single sim
Galaxy Note
So maybe the cellular radio or a faulty power button, is forcing the system into Airplane Mode. Have u tried running a diagnostic test thru Samsung Members, and or
Hard resetting it
Turn off the phone.Press and hold Volume Up + Power button until the recovery menu appears.
Use the volume keys to navigate to Wipe cache partition and press the power button to select it.
