Radio Problem ๐Ÿ˜…
(Topic created on: 07-05-2019 12:24 PM)
Aden97
Galaxy Note
Hi guyz, i am currently using Samsung Galaxy Note 9 mobile and i cant find Radio app in it ,if someones knows how to enable that app please reply  ๐Ÿ˜Š
8 Comments
NoorAalam01
Galaxy Note
๐Ÿ˜Ž
Aden97
Galaxy Note
bro ๐Ÿ˜… i needed an Answer not this (๐Ÿ˜Ž) ๐Ÿ˜…
Sidhabhi
โ˜…โ˜…
Galaxy Note
Qualcomm version supports fm radio..not sure about exynos version, if you want, you can check by adding some third party fm apps..
Sidhabhi
โ˜…โ˜…
Galaxy Note
If hardware(in built FM tuner) won't support, how is it possible?
For eg - S10+ hardware does support fm radio I.e it has fm radio receiver ( Its like a tuner and streaming is different thing) and to activate it, you must download some 3rd party apps..
CyberAtom
Galaxy Note
woah .... you seriously wanting to listen to the radio.... that's so cool !!
Tarunbabu1991
Galaxy Note
Samsung Note series and S series doesn't have FM Radio
Aden97
Galaxy Note
thank you guyz ๐Ÿ˜Š๐Ÿ˜Š๐Ÿ‘
Tarunbabu1991
Galaxy Note
You're most welcome
