Note20 ultra auto focus problem
(Topic created on: 07-10-2022 03:16 PM)
Sohan1997
Galaxy Note
After a OTA update  my note 20 ultra camera destroyed by Samsung. The main camera is not able to make auto focus. I need to shake the device to make it happen.
Here I am attaching a xample video.
10 Comments
MuzikD
Expert Level 3
Galaxy Note
Not having any issues in my unit. Try resetting camera settings and then have a look if issue still persist.
Sohan1997
Galaxy Note
I have been reset camera settings and also take it to the service center. also manually flash the software but not worked
Naushu97
Galaxy Note
Bro you have toh change your main camera I also had this issue...recently I changed that camera and issue get resolved
Sohan1997
Galaxy Note
is it under warranty or you had to paid ?
Naushu97
Galaxy Note
No bro I had charged for that 7000 rupees
Sohan1997
Galaxy Note
🤕 7000 ? its hurts.. I don't know how it damaged...
cs_member8
Galaxy Note
Dear Samsung member,
Thank you for sharing your concern. We acknowledge your query and apologize for the same. We apologize for the inconvenience you are facing And please follow the easy troubleshooting steps which might help to solve the issue.
Check the physical condition of your camera lens.
1. Broken camera lens.
2. Scratchy camera lens.
Please check there is no laminated or tempered glass pasted on the camera.
Use a microfiber cloth or a cleaning wipe. Gently remove the fingerprint, dirt, and dust from the camera lens.
If the issue has not been resolved then Reset camera settings
Please follow the below steps:
Step1: From the home screen tap on Camera.
Step2: Tap on Settings.
Step3: Scroll up and tap on Reset settings.
Step4: Tap on Reset.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback >Ask questions).
Rammish
Galaxy Note
I too have the same issue, and most probably after a software update. I have tried all these steps, but doesn't work.
PANDA32
Galaxy Note
I also have the same issue we should wait until the next software update
