Note20 Ultra edge Discoloration/ Dark edge
(Topic created on: 10-23-2020 02:22 AM)
trendygautam
Galaxy Note
I am getting Dark edges I am not sure what is this screenburn or what.
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung Member,
To resolve "display" issue kindly follow the given below steps:
1) Check device in safe mode: Press and hold the Power key, when Power off icon appears >Press and hold the power off icon.
Exit safe mode: Hold the power button and select restart on the device.
2) Reset the device: settings >General Management > Tap on Reset.
Note: Before reset make sure to have back up of the data via Smart Switch Mobile App
(Install Smart Switch App > Open > Click on Memory Card Icon >Back Up option > Choose the data for Back up > Back Up).
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question) with the screenshot so, that we can assist you accordingly.
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
