Note 8 earpiece volume is too low. works fine for few hours and then again low
(Topic created on: 12-01-2017 06:37 PM)
AngryPixel
Galaxy Note
It started few weeks back. suddenly call volume would be very low or sound would be crackling. Tried cleaning earpiece by blowing into it a d it sometimes works but not always. any suggestions what to do? I guess there is some blockage in the earpiece mesh.
5 Comments
admin_
Galaxy Note
Thanks for being a part of Samsung community. Would like to tell you kindly follow the steps below to resolve your concern:-
1) Navigate to apps >> Settings >> Apps >> Tap on three dots >> Reset app preferences.
2) Please run your device in safe mode.
3) Please do reset your device on factory mode after taking the data backup Via Smart switch. Be sure to hit ♡ when you find an answer that works for you.
AngryPixel
Galaxy Note
thanks but this won't work. It might have worked if the issue is persistent. Earpiece keeps on getting fixed on its own for few hours and then go bad again without any reason
Shivasrs
Galaxy Note
Even i'm also facing the same problem
roHan7220
Galaxy Note
i am also facing same problem even with speaker volume too..
AngryPixel
Galaxy Note
It stays away now if I keep the call volume to 50%. what's wrong with your flagship phone
