Note 8 earpiece problem
(Topic created on: 08-31-2018 06:38 AM)
bagkartanmay
Galaxy Note
Dear friends, i am facing problem regarding earpiece sound is very low, any other have this kind of problem? how should i fix this?
8 Comments
MiteshGajjar
Galaxy Note
I am not having such issue.
Galaxy Note
#ImranKhan
Yes You Right
Galaxy Note
#ImranKhan
No
gakshat14
Galaxy Note
Probably clean your ear, Just kidding
bagkartanmay
Galaxy Note
ha ha ha
Galaxy Note
maybe the earphones got damaged by water all the ear Buds would be larger for your ear change the ear buds too small it will work
Raj2051
Galaxy Note
go to service centre if really problem there they will replaced it in just 5-6 hrs
admin_
Galaxy Note
We do regret for the inconvenience caused as you are getting low sound in earphone. We would like to inform you to follow the steps below to resolve your concern:-
- Check with other earphone to find the cause.
- Open settings >> Accessibility >> Hearing >> Mute all sounds >> Enable and disable.
- Connect earphone open settings >> Accessibility >> Hearing >> Left/right sound balance >> Adjust in middle.
- Open settings >> Sounds and vibration >> Sound quality and effect >> Adapt sound >> Disable the preset.
- Please run your device in safe mode.
- Please do reset your device on factory mode after taking the data backup Via Smart switch and remove the Google account.
- If still issue persists, we would suggest you to visit nearby Samsung Service Centre in order to get your device and earphone physically inspected by the service engineer. Please find service centre details in the link provided -http://www.samsung.com/in/support/servicelocation
Be sure to hit ♡ when you find an answer that works for you. For further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
