Note 8 Battery Drain 20% to 0% in less than 2 minutes
(Topic created on: 09-27-2019 06:17 PM)
malhotrs
Galaxy Note
After pie update on my galaxy note 8 I am facing battery issue. It is draining from 20% to 0% in less than 2 minutes. I have tried factory reset also but it did not help.
Does anyone have a solution? Thanks in advance.
3 Comments
sonup
Galaxy Note
calibrate your battery percentage
with *#0228# on dial pad. minimum your device will charge 40 %
malhotrs
Galaxy Note
Thanks dear. Actually I had tried calibrating the battery a month back. I am not sure if that solved the issue because immediately after that there was another security update and the battery issue continued. Do we need to do battery calibration after every FW update?
malhotrs
Galaxy Note
anyone has a solution for this? I am still facing the issue. Samsung guys?
