Note 10 plus is heating and S Pen is not detected after May patch update
(Topic created on: 06-01-2022 10:49 AM)
Myukh
Galaxy Note
Hi All,
I am facing phone heating issue and my S Pen has suddenly stopped detecting after i did the May patch update on my Samsung Note 10 plus.
Before the update everything was working fine. I tried reseting the S pen no luck.
10 Comments
JithinAjith
Galaxy Note
1. Settings 》Apps 》tap 3 dots 》Reset app preferences
2. Settings 》Device Care 》Battery 》Background usage limits 》
* Deep sleeping apps 》select all apps
* Sleeping apps 》select all apps
3. Settings 》Apps 》
Android system Web view 》Tap on 3 dots 》uninstall update
Android system intelligence 》Tap on 3 dots 》uninstall update
Chrome 》Tap on 3 dots 》uninstall update
4.Update all apps
