Note 10 plus battery drain after updating
(Topic created on: 01-15-2022 09:56 PM)
msingh48
Galaxy Note
Note 10 plus battery is draning very fast after one ui 4 update even after system cache clear.
2 Comments
Galaxy Note
Bro you can hard reset but first backup your data some unknow gliches sometimes come in os updates hard reset will fix it and the battery will recalibrate after hard reset it will take 3 days for it
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
