Note 10 plus auto brightness doesn't work properly after one ui 3.0
(Topic created on: 02-07-2021 01:52 AM)
S_Kumar73
Galaxy Note
Auto brightness doesn't work properly after one ui 3.0 update. Even in dark room the slider stops at around 40% and it stays which is actually very bright at night. I tested with s21 ultra and in s21 ultra the slider reduces to 5%.
14 Comments
S_Kumar73
Galaxy Note
Yes
S_Kumar73
Galaxy Note
When we buying the phone, samsung giving everything right, buy after that they mess up everything In the name of software update.
Anni5
Galaxy Note
You got any solution for this ? My Note 10 Lite is also putting up the same tantrums in darkness.
S_Kumar73
Galaxy Note
No solution
burnahead
Galaxy Note
I got the same issue. It may caused by some Bixby routine like "bed time" or something else.
Try to remove the brightness setting feom all routines that contain the brightness change.
