__Note 10 _ Help _ Repair _ Glass Back & Front __
(Topic created on: 09-10-2021 10:39 PM)
_AbhiRajput_
Galaxy Note
SAMSUNG IS CHARGING TO MUCH REPAIR COST!
Should I go to service center or Other Store for Repair.
@Not under warranty
@Note 10
@Repair cost Approx _ 18k.
4 Comments
Galaxy Note
SERVICE CENTER IS BEST BCOZ BOTH SIDES GLASS HAVE BROKEN
AND IF YOU SPEND MONEY ON THIS THEN WHY GO TO OTHER PLACE INSTEAD OF SAMSUNG SERVICE CENTER AS ITS WILL BE REPLACED WITH ORIGINAL DISPLAY AND GLASS
THAT MAY NOT HAPPENS WITH OTHER PLACE
SUGGEST YOU TO VISIT SERVICE CENTER !
SrajTech
Galaxy Note
Hey, since both side glass is broken, this is not that high
I mean it is high but its glass and if you get it replaced at some local shop,you will have to compromise on quality and the local repair person can also steal some original parts from your phone and put some local part also
Its best to get it done at service center
sameergupta
Galaxy Note
Don't get it replaced from a local shop. Those nutheads only know how to open a phone and change the glass. These flagship phones have special type of adhesiv which won't allow water inside since these phones are IP certified. Local shop guys won't use anything as such and simply change the glass and screen. Also, screen wont be original so you'll definitely won't get the same feel. Premium smartphones come with heavy maintenence cost.
Galaxy Note
Dear Samsung Member,
We would request you to register your concern in Samsung Members Application. So, that our concern team gets back to you as soon as possible.
Please follow this path to register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Ask questions).
