Moisture problem in note8
(Topic created on: 08-09-2019 03:12 PM)
Not applicable
Galaxy Note
I clean the port and it is dry but when it is dry it shows moisture problem any solution
7 Comments
babi07
Galaxy Note
ok service center
Deepakj
Galaxy Note
put your phone for one night in rice(चावल) box.
Deepakj
Galaxy Note
after this tell me result
Tan98
Galaxy Note
l too faced same problem with my C7 pro but after last update the issue solved.
Mudy
Galaxy Note
you repair Note 8 from outsiders?
Mudy
Galaxy Note
this type of problem can't occur
Because Note is IP68 water and dust resistant
kohliteena29
Galaxy Note
usable post
