Resolved! Solved
Edge lighting not working in note 10 lite..
(Topic created on: 06-30-2021 04:38 PM)
DrPeter
Galaxy Note
 In my note 10 lite,
 Edge lighting is not working, eventhough I turned it on.
The lighting effects is not showing up  when an notification is received.....
 What should I do ??
 What should I do ????
Resolved!
DrPeter
Galaxy Note
How to make it work?
VTProGenius
Galaxy Note
Well, then can you do a screen record of you showing settings and make a notification come from your other phone or something
VTProGenius
Galaxy Note
Ohhh, I really sorry, I forget 😔 Edge Lighting only works on messaging apps unless you have third party apps such as Good Lock! Sorry for wasting time... Go to notifications, click brief notifications, Go to effects, and click echo
DrPeter
Galaxy Note
I have goodlock..
Previously, it worked for all apps....
But, now only, it is not working..
VTProGenius
Galaxy Note
It's because they recently took Good Lock from India
VTProGenius
Galaxy Note
Yes, but still usable with VPN us 🇺🇸 ones
Not applicable
Galaxy Note
For me it doesn't, because now Edge Lighting is in a different place, not like before in a same place with Edge screen. And it has Android 10, he confirmed it in my direct messages.
VTProGenius
Galaxy Note
Well, don't worry I solved his issue 😉
VTProGenius
Galaxy Note
Use theseScreenshot_20210630-184954_One UI Home_1193.jpgScreenshot_20210630-185447_Settings_1195.jpgScreenshot_20210630-184918_Settings_1190.jpg
VTProGenius
Galaxy Note
A screen record of the issue would help!
