Camera problem in Note 20 ultra
(Topic created on: 01-02-2022 08:20 AM)
Knightfury84
Galaxy Note
Using android 11 and having blur issue from 1x to 4x auto focus is not roing well....any suggestions....
6 Comments
Sattri3
Galaxy Note
same happen with me in note 20u
Knightfury84
Galaxy Note
sarfarazahmed
Galaxy Note
Try to clear the cache and data of camera app
Knightfury84
Galaxy Note
I did everything bro reset,hard reset,camera reset, all done but its still blury but in service center they told to wait till one ui 4
Sattri3
Galaxy Note
m olwys do it reset camera reset extra but nothing happen
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung member,
Thank you for sharing your concern. We acknowledge your query and apologize for the same. We apologize for the inconvenience you are facing And please follow the easy troubleshooting steps which might help to solve the issue.
Check the physical condition of your camera lens.
1. Broken camera lens.
2. Scratchy camera lens.
Please check there is no laminated or tempered glass pasted on the camera.
Use a microfiber cloth or a cleaning wipe. Gently remove the fingerprint, dirt, and dust from the camera lens.
If the issue has not been resolved then Reset camera settings
Please follow the below steps:
Step1: From the home screen tap on Camera.
Step2: Tap on Settings.
Step3: Scroll up and tap on Reset settings.
Step4: Tap on Reset.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback >Ask questions).
