Abnormal battery drain and heating issues.
(Topic created on: 10-04-2018 02:23 PM)
nish22
Beginner Level 3
Galaxy Note
Hi.
I am a galaxy note 8 user, and i've been facing battery drainage on standby mode and the device becomes warm on standby.
Does anybody else face these kind off issues?
3 Comments
mk99
Galaxy Note
i don't have any heat problems but i have battery drain problem but i fixed it by resetting settings and uninstalling apps consuming more then 5percent of battery.if u r playing pubg then nothing will save your battery percentage.
nish22
Beginner Level 3
Galaxy Note
no...i dont play pubg
admin_
Galaxy Note
Thank you for Joining Samsung community. We would recommend you to follow some troubleshooting steps in order to further isolate what you may be experiencing in your device. Find the troubleshooting steps on the provided link http://www.samsung.com/in/support/skp/faq/1101689. Please let us know what steps you have taken and if you have noticed any changes or improvements as this will help the Community to provide you further troubleshooting steps without repeating any procedure which you may have already followed. Be sure to hit ♡ when you find an answer that works for you.
For further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
