system problem
(Topic created on: 03-09-2021 02:10 AM)
abhinavraj12apr
Galaxy M
Why sometime my device restarts automatically....???? What should I do for this..??.
10 Comments
Strangeneria
Galaxy M
check whether this feature is on or off
Turn off or schedule it to time when you don't use your phone!!
Galaxy M
already off
Ehsank
Galaxy M
Try these steps and lets see
A. Clear Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
(Connect with type C cable/type C earphone only for Android 11)
OR
IF YOU HAVE ANOTHER MOBILE THEN CONNECT WITH CABLE WHETHER IT IS TYPE C TO TYPE C OR MICRO USB PORT take help of otg connector to connect other mobile.
2) Press and hold the Volume Up key and the power button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. go to safemode and observe is there same issue in safemode too
if not then problem may due to other downloaded apps
and if same issue in safemode then try to visit service centre
steps to turn safemode;
long press on power button>
long press on power off option>click on safemode >your mobile will restart and turn into safemode.
Keep in mind that in this mode only inbuilt system app will work
Galaxy M
i tried safe mode nothing happened
Ehsank
Galaxy M
so if safemode nothing happened then its might be due to some apps did u download any app recently
Galaxy M
okay I'll look for it
Galaxy M
and thanks for help I learned how to enable safe mode which I didn't know before
Ehsank
Galaxy M
my pleasure dear ,i wish soon ur problem get resolve 😊🤞👍
Samsung_Support1
Galaxy M
Dear Samsung Member,
Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
