03-12-2023 09:44 PM in
Galaxy M- Mark as New
03-12-2023 10:11 PM in
Galaxy M1. Clean the fingerprint scanner: Ensure that the fingerprint scanner is clean and free from any dirt or debris that may be interfering with its function. Use a soft cloth or tissue to gently wipe the scanner.
2. Delete and re-register your fingerprints: Try deleting your existing fingerprints and re-registering them. To do this, go to Settings > Biometrics and security > Fingerprints, and then select the fingerprint you want to delete. Follow the prompts to delete the fingerprint, and then re-register it.
3. Check for updates: Make sure that your Samsung Galaxy M30 is running on the latest software update. To check for updates, go to Settings > Software update > Download and install.
4. Restart your phone: Try restarting your phone and then check if the fingerprint scanner is working properly.
5. Reset your phone: If none of the above steps work, you can try resetting your phone to its factory settings. Before resetting your phone, make sure that you have backed up any important data.
If the problem persists even after trying these steps, it may be a hardware issue, and you should contact Samsung customer support or visit a Samsung service center to have it checked and repaired.
If you find my advice helpful. You can click on 3 dots near my comment and accept it as a solution to help others. This mean a lot to me. Thank you😊
03-12-2023 10:15 PM in
03-12-2023 10:17 PM in
03-12-2023 10:24 PM in
Galaxy M
03-22-2023 06:00 PM in
Galaxy MDear Samsung Customer,
When you scan your fingerprints on the device, be aware of the following conditions that may affect the feature’s performance:
• The fingerprint recognition sensor recognizes fingerprints. Ensure that the fingerprint recognition sensor is not scratched or damaged by metal objects, such as coins, keys, and necklaces.
• The screen protector supplied with the device may cause the fingerprint recognition sensor to malfunction. Remove the screen protector to improve fingerprint sensitivity.
• Ensure that the fingerprint recognition area and your fingers are clean and dry.
• The device may not recognize fingerprints that are affected by wrinkles or scars.
• The device may not recognize fingerprints from small or thin fingers.
• If you bend your finger or use a fingertip, the device may not recognize your fingerprints. Make sure to cover the entire fingerprint recognition sensor with your finger.
• To improve recognition performance, register fingerprints of the hand used most often to perform tasks on the device.
• In dry environments, static electricity can build up in the device. Avoid using this feature in dry environments or before using the feature, discharge static electricity by touching a metal object.
Note: You should make sure to use the highest central parts of fingerprint or the most curved part of fingerprint when you register or scan fingerprint
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Thank you for writing to us.
Samsung Customer Support.
01-25-2025 12:20 PM in
Galaxy M
