samsung galaxy f41 battery drain issue and lag issue
(Topic created on: 12-10-2020 08:53 AM)
theblacklover
Galaxy M
After 2.5 update battery drain fast and minor lag issue opening apps after 2 or 3 days restarting the phone
3 Comments
Ehsank
Galaxy M
i suggest you to if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
Ehsank
Galaxy M
if my given settings/comments will work for you then you can accept as solution by CLICKING on 3DOT at my comment
cs-member13
Expert Level 4
Galaxy M
Dear Samsung Member,
We apologize for the inconvenience caused to you. We would request you to kindly send us the screenshot, video and error log file with in 15 minutes of issue occurrence through error report section from Samsung Member Application:-
Samsung member application > Click on get help > Send feedback > Error report, so that we can help you out with this.
