10-10-2019 07:00 AM in
Galaxy M- Mark as New
10-10-2019 07:09 AM in
Galaxy Msettings
then
biometrics and securities
then
other security settings
then
on pin windows options
after on pin windows
u fill find that multi windows working
if not then u can contact customer care
with samsung chat
or phone number
or mail
10-10-2019 07:20 AM (Last edited 10-10-2019 07:20 AM ) in
Galaxy MWhen in recent apps, tap the small app icon above the app windows that is active, and you will find an option there for Open in Split Screen View.
10-10-2019 07:43 AM (Last edited 10-10-2019 07:43 AM ) in
10-25-2019 12:18 AM in
Galaxy MI'm feel to work multi window
05-25-2021 05:21 PM in
Galaxy MFinally i got a solution for it
Install good lock from galaxy store>install one hand operation + >
Open one hand operation + > right or left hand add "task switcher" swip it and click 3dots for App pop up will be work...🤗
if u find this helpful kindly click on the three dots and click accept as solution...😊
