flash light problem in m30s
(Topic created on: 12-09-2019 08:14 AM)
SauravWarrier
Galaxy M
Dear Sirs
After the update to Nov 1 patch following are experiencing.
1. The flash light is not turn on.
2. The camera takes a white blank shot while flash is on. The flash light glows while taking photos. If we off the flash in the camera it takes picture.
10 Comments
Comsup
Galaxy M
re flash the firmware at service center , OTA update is left some file while downloading thats why this happend .. get the same Update flashed from service center
SauravWarrier
Galaxy M
does any one has solution. had a chat with samsung. advised to clear cache, data, reset app preference, and to do factory reset.
done every thing. no result
anup0085
Galaxy M
Nothing is going to happen. I also tried everything suggested above but no result.
kiran7697
Galaxy M
bro just go to service centre and get repaired. like I did u can check my profile posts so that u will know what I did step by step
kiran7697
Galaxy M
my phone is working good now
SauravWarrier
Galaxy M
any problem while taking pictures with flashlight. check all modes in camera
SauravWarrier
Galaxy M
whether they open your phone for repair
kiran7697
Galaxy M
they opened I m sure replaced some part inside phone but now everything working good bro just go there and get your phone repaired
Samsung_Support4
Galaxy M
Hi there,
Please follow the below mentioned steps in order to resolve the issue:-
1) Clear the Cache of the camera (setting>>apps>>camera>>storage>>clear data and cache).
2) Do the reset settings of the camera (camera>>setting>>reset setting).
3) Do the reset app preference (setting>>apps>>three dots on the right top>>reset app preferences).
Then kindly restart the device and check the issue.
For further assistance, register your concern in Samsung members app (click on “+“icon>send feedback>Error report/ Ask Questions).
Regards,
Team Samsung Members
