Samsung m16 My phone battery is very fast drain
(Topic created on: yesterday)
Abhaytrivediabhay
Galaxy M
My  phone doesn't  not proper work
Zain1999
Galaxy M
Batteries have a life of 3-4 years in ideal conditions. There are some factors you can change to lead your device to better battery health, here are the following:
• Use battery saving mode,
• Turn off location, mobile data when not in use,
• Use battery protection that will limit battery to 85% which will increase the longevity of the battery as conapired to charging it to 100%,
• See which apps utilize the most battery are disable background usages usually it is Google play services.
Other factors to keep in mind:
• If you dropped your phone, your battery can be negative affected and there is a very small chance of malfunction by consuming more battery.
• Using phone outside 15°-35°C isn't optimal for your battery.
If this answer was helpful, click on the three dots and mark this comment as a solution. Thank you for reading.
