M35 Battery Drain!
(Topic created on: 10-28-2024 09:39 AM)
Marqs
Galaxy M
Any one facing faster battery draining after the October update?
11 Comments
KASHMIRIAWSAF
Galaxy M
gooddoy
Galaxy M
M51 samsung display problem green color issues
goodthings
Galaxy M
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution . Thanks.
goodthings
Galaxy M
Your's most welcome to here.
cs_member8
Galaxy M
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open the Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select Error report > select the appropriate issue category> Type your query and send).
Aspire7891
Galaxy M
Yes
Mayur000
Galaxy M
Kindly wait for 30 days, maybe you will get a better battery backup
JithinAjith
Galaxy M
Settings 》Google 》Devices 》Turn off scan for nearby devices
Settings 》Connections 》More connection settings 》Printing 》Turn off default printing service
Device care 》Battery 》Background usage limit 》Deep sleeping apps 》 add apps
Settings 》Location 》Improve Accuracy 》Turn off Bluetooth and WiFi scanning
