M30s Battery drain after updating Android 11 with One UI 3
(Topic created on: 02-20-2021 04:08 PM)
Arun410
Galaxy M
I updated my M30s with Android 11 One UI 3 a week ago. Since then battery is draining unnecessarily without any usage. In one night in standby mode it drains around 10% which was earlier around 2% in One UI 2. I even tried heart resetting my phone but to no use. I don't know whether there will be any update with the issues being addressed. So i would not recommend to update the phone to Android 11 without any clear view about its performance .
Anyone faced the same issue and has any solutions kindly reply.
15 Comments
Ehsank
Galaxy M
8-10 hrs is good enough
so do one thing once check from 100-0 to identify excact sot
Arun410
Galaxy M
it came around 4 hr 30 mins in Andoird 11
Ehsank
Galaxy M
from 100-0 % its strange and equally impossible to understand 🤔🤔🤔
Ehsank
Galaxy M
and if you feel only just after update then as of now perform these below steps;
A. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
(Connect with type C cable and connect withpc/laptop only for Android 11 )
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
C. Go to settings >general Management >reset>reset settings.
Galaxy M
yes I am also facing the same
Samsung_Support1
Galaxy M
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
