Fast charging and fast draining problem from 90 to 100%.
(Topic created on: 02-05-2022 12:56 PM)
ayaatmehraj
Galaxy M
I am using m02 and i am facing problem of charging.My phone get fast charge from 90 to 100% and also from 100 to 90% it drains so fast without use.Otherwise my phone from 0 to 89% charges perfectly and no battery drainage.if Anyone have solution please tell me.
23 Comments
Galaxy M
Same here
Galaxy M
5000 mah working like 3000 mah
ayaatmehraj
Galaxy M
Yeah right.
deepcat89
Galaxy M
Reset phone ,remove unwanted apps, disable unused apps to sleep. Turn off location, Bluetooth, GPS . Remove heavy apps like fb and others which consumes space .
klnpranav
Galaxy M
Over usage of phone and keeping background active may cause a battery damage or hang issues
ayaatmehraj
Galaxy M
I don't keep background active and i don't overuse my phone.This problem only happens if i charge from 90 to 100%.i don't know why from 90 to 100 it gets fast charge and also drains fast without any use.
klnpranav
Galaxy M
Then once reset it or delete all apps and re install it
ayaatmehraj
Galaxy M
I done the same but nothing works.
klnpranav
Galaxy M
Then all u have did so go to settings keep powered mode in that optimised mode and leave it for an day (or) replace it with new battery
