Direct call not working in edge panel
(Topic created on: 07-24-2022 11:28 AM)
ARJUNB
Expert Level 3
Galaxy M
Friends one thing I am not able to understand here. Direct call is not working on m51 no problem. But it is working on.
A30s, f23, a73 what is happening.
All the above models are working with direct call in edge panel. Any solutions to run in m51 suggest.
3 Comments
ARJUNB
Expert Level 3
Galaxy M
Reporting done long time back. Update also received but the thing is that it is a 3rd party app on edge panel. So samsung has got nothing to do with it.
cs_member8
Galaxy M
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same and please follow the easy troubleshooting steps which might help to solve the issue.
On the Home screen, tap Apps.
In the Apps screen, swipe to the page that contains the Settings icon (if necessary) and then tap Settings.
Tap Advanced Features.
In the Advanced Features screen, swipe up on the screen until you see the Direct Call option.
Tap Direct Call.
In the Smart Alert screen, move the toggle button in the upper-right corner of the screen from left to right. The Smart Alert status at the top of the screen is On.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Thank you for writing to us.
Samsung Customer Support.
ARJUNB
Expert Level 3
Galaxy M
Are you serious or are you a joke. Honestly first learn about samsung and then comment. Ok.
This was done when mobile phones used to run on Marshmallow, Nougat, and Oreo.
Not anymore.
Beta first learn samsung and then comment on others. Bachai
