Camera light sensor is consuming huge battery in M31
(Topic created on: 09-01-2022 05:45 PM)
Sabbih
Galaxy M
Can anyone help me out? See the screenshot. And suggest what I can do. It'd be appreciated.
N.B.
1. I keep adaptive battery turned off.
2. I keep the camera related sensors turned off (like, keep screen awake feature)
Other tips are welcome.
26 Comments
Galaxy M
Turn off adaptive brightness mode and check
Sabbih
Galaxy M
I already mentioned that in the post. But, thanks for reaching out.
Galaxy M
Once turn off face unlock and try
Sabbih
Galaxy M
I keep that turned off as well. In fact, anything related to camera light related stuff is turned off, still facing this issue every once in a while. That's why I posted it here today.
Sabbih
Galaxy M
Look at this screenshot. It's increasing like crazy. I have no clue.SmartSelect_20220901-202231_Device care_22045_1662042151.jpg
kingshukkhan
Galaxy M
You can force stop camera apk, reset your device and then restart device......
Sabbih
Galaxy M
Resetting the device is not an easy thing, you know. It'll be the last thing I'd do. But I want to see if any other solution arrives here.
kingshukkhan
Galaxy M
camera light sensor can be uninstall.....
Sabbih
Galaxy M
How? Can you show me the way? I found this from the Developer tool. See the screen shot. SmartSelect_20220901-204053_Settings_22048_1662043253.jpg
