Camera light sensor battery drain
(Topic created on: 06-14-2020 05:25 AM)
Senthill
Galaxy M
Getting this problem for the past 2 week, this sensor consumes particular percentage of battery  daily, but haven't had this problem  before,  any solution apart from turning off adaptive brightness?
bkiyoshi
Galaxy M
Same issue gere. Even with adaptative lighting off.
Satvashil
Galaxy M
Smart stay keep screen ON when you are looking at mobile by using front camera with help of CameraLightSensor.
Go to settings=> advance features => motion and gestures=>turn off smart stay.
shivk_yadav
Beginner Level 3
Galaxy M
Same problem, since last 2 weeks.
Satvashil
Galaxy M
MarianC
Galaxy M
Device care update was my problem. I uninstalled the update and the issue was resolved.
Samsung_eIvTciV
Galaxy M
How did you uninstall the update. I am facing the same issue of battery drain due to this System App.
pankaj7619
Galaxy M
i am using samsung m30s..daily 20 to 25% is consumed by camera lightsensor, it's showing daily 16hr showing time time in baytery...how can solve that problem,i did trying off my facelock but happened.
Rishi77
Galaxy M
Did you put a screenguard on it which covers the front camera?
AN86
Beginner Level 5
Galaxy M
similar issues are cropping up in my phone
Piyushm143
Galaxy M
turn off 'always on display '
