Call disconnect problem on buggy m52 5g
(Topic created on: 04-06-2022 03:06 PM)
yuvrajchoudhary
Galaxy M
Updated my m52 5g today morning with oneui 4 (android 12). And now I can't call anyone.
Each call drops automatically after 10-15 seconds. Very annoying.
4 Comments
vivek1989
Galaxy M
I m not facing this prblm
indeep
Galaxy M
Use jio
Galaxy M
You Mean android 12 only works with jio : )
cs_member8
Galaxy M
Dear Samsung Member,
We apologize for the inconvenience you are facing. We understand your concern and will help you resolve this. Kindly follow the below steps to resolve your issue:
Check device network mode settings
Please follow the below steps.
Step1: Navigate to apps screen and tap on Settings.
Step2: Tap on Connections.
Step3: Tap on Mobile networks.
Step4: Tap on network mode SIM1 or SIM2.
Step5: Select network mode.
Note: We recommend to set device network mode as LTE/3G/2G (auto connect) mode.
Check network operator settings
Kindly set device network operator as "Automatically".
Step4: Tap on Network operators.
Step5: Select automatically.
Note: We recommend to set device network operators as LTE/3G/2G (auto connect) mode.
Step6: Tap on OK.
Step7: Registered on network.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
