Resolved! Solved
Battery draining issue
(Topic created on: 03-31-2021 10:17 AM)
BlackKnight18
Beginner Level 3
Galaxy M
Since 26th March update for #GalaxyM51 (M515FXXU2CUC2), #battery is draining quickly. No background apps allowed to run in background. No heavy gaming use. Is there anyone facing problem regarding battery?
Ehsank
Galaxy M
one of the main reasons of battery drain is background activity,
even you close apps but they uses ur battery and running in background unnecessary, see image(1) and read the statement.
2nd due to huge notification options.
for e.g ; Google has huge notification which we don't need at all see image(2) just scroll up and down and check how many notification it does have.
So do these settings to stop, which consume battery unnecessarily.
1. Settings>>Connection>more connections settings> disable nearby device settings
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
8 Comments
nehraram
Galaxy M
Nope
Kenzen
Galaxy M
Try removing the unnecessary/unused apps.. Maybe becz of these unnecessary apps the battery is draining quickly.. Also enable the power saving mode on your device it may reduce the consumption of charge to an extent..If you found my comment helpful please accept the solution by click on the three dots above my comment»Accept solution.. Thank you.
Kenzen
Galaxy M
If the problem is not still solved then it may be solved in future patch updates which will fix the problem..
BlackKnight18
Beginner Level 3
Galaxy M
already done whatever you suggested. only necessary apps installed.
Ehsank
Galaxy M
A. Wifi scanning
Ehsank
Galaxy M
Besides above settings do some more settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
FOR ANDROID 11;
A. DEVICE CARE > Battery>Background Uses Limit > Put Unused App to Sleep
B. Device care>click on 3dot at top right corner>automation>adaptive power saving
C. Device Care > Battery> More Battery Settings>Adaptive Battery
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info (ibutton> then go to these 3 options below on by one
5. Go to settings> privacy > permission manager > location> and check which app have accessing your location all the time and if not using that apps then deny access or set as " allowed only while in use"
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > checkwhich app syncing automatically there and if any app which not necessary to auto sync then click on it and disable sync.
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
imganesh
Galaxy M
I am using m51 one ui 2.5 should i update one ui 3
BlackKnight18
Beginner Level 3
Galaxy M
yes.. you should.. current update is much stable than ui 2.5. Only few M51 customers facing phone heating and battery drain issue.
