Battery draining issue
(Topic created on: 01-05-2022 12:27 PM)
ck3040
Galaxy M
Hi, i am using samsung m31s mobile,I saw some battery draining issue from last few days and its drains 10% to 12% in overnight without usage.
So please consider my request and fix the bug🙏
7 Comments
Not applicable
Galaxy M
Are you using maximum power saving ?
ck3040
Galaxy M
No
Not applicable
Galaxy M
if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
FOR ANDROID 11;
A. DEVICE CARE > Battery>Background Uses Limit > Put Unused App to Sleep
B. Device care>click on 3dot at top right corner>automation>adaptive power saving
C. Device Care > Battery> More Battery Settings>Adaptive Battery
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info(ibutton)>> go to these 3 options below on by one
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> Manage account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on weather settings (icon)> change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
Credit- Ehsank
Not applicable
Galaxy M
Turn on adaptive power saving mode from device care. It will turn on power saving mode When u aren't using your device.
if u found this helpful then click on the 3 dots of this comment and accept it as solution
omji125
Galaxy M
Due to cold season.
Player786
Galaxy M
Some software updates and apps are also responsible for this issue.
cs-member13
Expert Level 4
Galaxy M
Dear Samsung Member,
We acknowledge your query and apologize for the same. To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
