Battery drain issue
(Topic created on: 10-04-2022 06:41 AM)
Niloy_Ganguli
Galaxy M
I am update my Galaxy M12 on android 12. But after the update my phone battery life is very very bad performance..
3 Comments
Galaxy M
Reset your device once. It will be helpful to get better battery backup
Niloy_Ganguli
Galaxy M
I have done factory data reset
cs_member8
Galaxy M
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. And please follow the easy troubleshooting steps which might help to solve the issue.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
