EdVinu
yesterday in
Galaxy M
Hello everybody,
My galaxy m55 has an serious major issue of battery drain it gives only 4-5 hours of battery life. And I'm not playing heavy game and not use heavy apps and I also not using heavy editing . But my galaxy m55 battery drains as the open source of water . I restricted all apps in background . And limit app to use mobile data in background. But my samsung m55 drain as quick as bullet train. I bought my samsung m55 in year 2024 month October.
I post a comment several month ago about samsung m55 poor camera quality and heating issue and low performance. But no one help me in this problem about my phone
5 Comments
BiRdMaN
yesterday in
Galaxy M
Yes, many users have reported experiencing similar problems. This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
EdVinu
yesterday in
Galaxy M
Do you think I am crazy that I would not have applied all these tricks
EdVinu
yesterday in
Galaxy M
I used this solutions bro
goodthings
yesterday in
Galaxy M
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
yesterday in
Galaxy M
Your's most welcome to here.
