Resolved! Solved
Battery drain issue in m21
(Topic created on: 08-31-2020 08:58 AM)
VigneshR
Galaxy M
I have brought a new Samsung M21 with 6000mah battery but I am not convinced with the battery backup .my battery drains within one day with normal usage (no gaming) and with less installed apps. When I calculated the battery draining percentage with a stopwatch I found out that my battery drains 1% along 10 minutes . Is it normal if not please tell any solution.
Galaxy M
Follow this tips-
1.Restart your phone daily .(Use Auto Restart.)
2.Turn Off all notifications of unwanted apps.
3. Use Dark Mode with Dark Wallpaper.
4. Charge your phone till 90-95 % only and don't use your phone when it is below 20%.
5. Lower the screen brightness at the level you can see and Turn Off Adaptive Brightness.
6. Turn Off Wifi, Bluetooth, Portrait, Always On Display, Sync, Location, Mobile Hotspot, etc. when not in use. (Note:- Full form of etc is et cetera ).
7. Put your all the apps in Sleeping Apps which can find in Device care> battery.
8. Don't use Fast Charging this causes heat which may affect your battery because of heat may be there will be more reaction in battery.
9. Set your phone to 'Optimised' and Turn On Adaptive power saving also turn on 'Put unused apps to sleep' in App power management.
10. Turn ON 'Auto optimisation' and 'Optimise settings' by clicking three dots in Device care.
11. Turn OFF 'Allow background data usage' of all the apps.
12. Turn Off 'Nearby device scanning'.
13. Set your screen timeout to 30 sec.
14. Turn OFF 'Vibrate while ringing' in sounds and vibration settings.
15. Set your wallpaper services at None and turn OFF 'Show guide page'.
16. Turn OFF 'Touch sensitivity'.
17. Turn OFF 'Search from home' which is available in Home screen settings.
18. Turn OFF 'Find My Mobile' if you think that your phone may not be theft.
19. Turn Off 'Screen Transition effect' in Biometrics preferences.
20. Turn OFF 'Wifi-scanning' and 'Bluetooth scanning' in Improve accuracy settings.
21.Turn OFF ' Smart stay + Lift to wake + Easy mute + Finger sensor gestures + Smart Alert + Double tap to wake.
22. Turn ON 'Reduce Animations'.
23. Check the running services whether any unwanted apps or features are turned ON , if ON then stop it by clicking on them.
( Note:- Running services is available in Developer option only, for using it turn ON Developer option.
24. Lower the sounds because it doesn't decreases your battery but also your hearing ability.
25. Turn OFF 'Allow Background Activity' of all the apps.
26. Turn OFF 'One-handed mode' , use your both hands as God gifted you but remember don't use your both hand for washing your bum, use one hand only,
just joking 🤣🤣🤣.
Please accept it as solution by clicking three dots because it will help others to find solutions easily related to this problem
15 Comments
Galaxy M
Follow this tips-
just joking 🤣🤣🤣.
VigneshR
Galaxy M
in short I have to sacrifice everything to save my battery😅
Galaxy M
brother without sacrifice we nothing achieve in life , I also sacrificed 🤣🤣🤣 then only I am getting 2 days battery Life
VigneshR
Galaxy M
why did you told to charge upto 90-95% why not 100. I have heard from so many yt videos too.
Galaxy M
dear brother, NO, that's VERY BAD for your battery.. always keep the battery between 20%-95% (ideally never below 40%, but definitely never below 20%, and never above 90- 95%).. unplug it when it reaches 90% . If you plan to store the phone away, keep the battery at 50%. That's why when you buy a brand new phone, notice the battery is always usually charged to around 50% (more or less) so it doesn't wear out the battery during long term storage and shipment. If you keep it between 20%-90% and unplug the charger at 90%, you can make your phone battery last 200% longer (or maybe even more) and last many more years.. this is confirmed by studies and tests.
if you satisfied then accept it as solution
Or hit one like also so I can motivate
Raju1729
Galaxy M
After all things are turned off, then what is the use of mobile! . We purchased to use all the features no!
Members_DQMfWFc
Galaxy M
Justvturn off the phone & save all the juice, isn't it? 😅
Ehsank
Galaxy M
you learnt copy paste art like others😆😆😆😁
Ehsank
Galaxy M
achha aisa hai kya😆😆😆😆😁😁👍
