10-07-2020 09:07 AM in
Galaxy M- Tags:
- samsungmobile
10-07-2020 09:16 AM in
Galaxy M- Mark as New
10-07-2020 10:03 AM in
Galaxy M》Remove useless apps
》Check which app is consuming more battery
》Don't charge your phone for hours and hours
》Sleep unnecessary apps
If you think my opinion is correct click on top three dots and click accept solution
10-07-2020 10:13 AM in
Galaxy Mhttps://r2.community.samsung.com/t5/Tech-Talk/Battery-saving-tips/td-p/2920797
10-07-2020 10:26 AM in
10-07-2020 11:01 AM (Last edited 10-07-2020 11:02 AM ) in
10-07-2020 12:11 PM in
Galaxy MA. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
10-07-2020 12:13 PM (Last edited 10-07-2020 12:13 PM ) in
Galaxy M1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, INSTA,YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery?)
6. If you use Facebook frequently then disable "auto play video"
10-07-2020 09:28 PM in
Galaxy M1. clear cache partition
2. drain the battery completely until it doesn't turn on.
3. charge the device to 100 in switchoff mode for good results.
4. again drain and charge again for 100. do this twice.
5. once done use your device between 20-80% for better battery life.
10-08-2020 10:56 PM in
Galaxy MDear Samsung Member,
Please visit this mentioned link to resolve your device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
