Battery drain in Samsung M51
(Topic created on: 12-08-2020 10:45 AM)
KarN16
Galaxy M
       I charged my battery to 100% at 1 am and when i checked my phone at 8am it was 86%. So there was 14% drop in standby mode which shouldn't happen. i will attach my screenshot for reference.
It wasn't showing any app running in background too. This is first time i experience battery drain issue.
 Is anyone else experiencing this?
15 Comments
Manusailu99
Galaxy M
U r correct brother.. I am also experiencing Battery drain problem in my m51 .. plz resolve Samsung technicians..
KarN16
Galaxy M
Mine is 74 its moderate drain only, even my old phone Mi A1 didn't have so much drop in standby mode inspite of its less battery.
KarN16
Galaxy M
I use that feature. Shall wait and see if this problem is consistent.
Ehsank
Galaxy M
one of the main reasons of battery drain is background activity,
even you close apps but they uses ur battery and running in background unnecessary, see image(1) and read the statement.
2nd due to huge notification options.
for e.g ; Google has huge notification which we don't need at all see image(2) just scroll up and down and check how many notification it does have.
So do these settings to stop, which consume battery unnecessarily.
1. Settings>>Connection>more connections settings> disable nearby device settings
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
Ehsank
Galaxy M
Besides above settings do some more settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings> privacy > permission manager > location> and check which app have accessing your location all the time and if not using that apps then deny access or set as " allowed only while in use"
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > checkwhich app syncing automatically there and if any app which not necessary to auto sync then click on it and disable sync.
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
KarN16
Galaxy M
Wow thanks i will try this, only thing which i was not happy is this battery drop this wasn't case in my old phone even if it had 3000mah battery
Ehsank
Galaxy M
just do each steps and observe, i hope you will get a noticeable difference as i said earlier
Ehsank
Galaxy M
if my given settings/comments will work for you then you can accept as solution by CLICKING on 3DOT at my comments
KarN16
Galaxy M
yes shall see for 2-3 days how it goes
