10-19-2019 09:40 AM in
Galaxy M- Mark as New
10-19-2019 11:15 AM in
Galaxy M
10-19-2019 11:36 AM in
10-20-2019 07:56 AM in
10-26-2019 12:55 AM (Last edited 10-26-2019 12:56 AM ) in
11-01-2019 11:39 AM in
Galaxy MBattery draining after recent software updates.
01-05-2020 07:22 PM in
Galaxy Min long term it doesn't give good battery backup
but in short (I.e. in continuous usage) it gives a humongous battery of almost 12 hrs battery
01-27-2020 07:31 AM in
02-29-2020 10:06 PM (Last edited 02-29-2020 10:07 PM ) in
Galaxy M@sunil45 The idle/standby battery drain is very high. Battery losses around 15-20% overnight which is not normal at all when a phone is not in use.
I keep everything sync, wifi , no recents and no google photos uploading photos but the battery discharges at a tremendous rate.
I only face the high battery drain when I'm not using the phone that is when the phone is in IDLE/Stand-by mode. Heavy gaming it just drains at rate of 10% per hour which is good I guess.
Once again losing around 20% of battery overnight is not right at all.
Also, the phone does not go into deep sleep mode as it was showing in 'Accu battery' app.
I'm posting my battery usage stats in the link, you can check them out. You will be able to notice the battery always keep on discharging(at 2-3% per hour) and doesn't hold the charge.
BATTERY USAGE STATS LINK :
https://drive.google.com/open?id=1BIKGG2VSd0WDew4OzT0Iz_70m3EgLGVw
P.S. : I am trying very hard to solve this issue so I am posting battery usage links on every thread related to Samsung m30s battery drain.
02-29-2020 10:08 PM in
Galaxy MThe idle/standby battery drain is very high. Battery losses around 15-20% overnight which is not normal at all when a phone is not in use.
