After updating android 12 4.1 battery drain very fast please fix it
(Topic created on: 04-27-2022 05:13 PM)
Devender5
Beginner Level 5
Galaxy M
Battery drainage
2 Comments
Ab_Heartsy
Expert Level 3
Galaxy M
It's normal after every major OS updates, try reading my post about tips for One UI 4 update n follow those 3 steps, it might help.
cs_member8
Galaxy M
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
