ashishgautam
02-28-2019 08:24 AM in
Galaxy J
Sir mere mobile j4 2018 me battery drain fast ho rhi he
Rakhe hue mobile me hi 1 hours me 10% discharge ho jata h or heating ki problem bi aa rhi he.
Please kuch solution dijiye. Reset bi kar liya ye
6 Comments
GIVEUP
02-28-2019 07:20 PM in
Galaxy J
1. do not use 3rd party apps 2.keep unused app on sleep 3.do not run your phone when it is charging 4.keep restarting your phone every week 5.be happy 🤗🤗🤗🤗😏😏😏🤗🤗🤗
GIVEUP
02-28-2019 07:22 PM in
Galaxy J
I ALSO THINK THAT THIS A SOFTWARE PROBLEM !!! WAIT FOR YOUR NEXT SOFTWARE UPDATE , YOUR PROBLEM WILL BE SOLVED !!!
bupendrasharma
03-02-2019 12:55 AM in
Galaxy J
ooohhh
admin_
03-02-2019 04:30 PM in
Galaxy J
Thank you for sharing your concern. We apologize for the inconvenience caused to you. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
ashishgautam
03-04-2019 09:10 AM in
Galaxy J
are bhai reset karne ke bad koi apps install ni karta fir bi rakhe hue phone me heats or battery drain hoti h yar
ashishgautam
03-04-2019 09:13 AM (Last edited 03-13-2019 11:07 PM ) in
Galaxy J
feedback 28 Feb.ko diya but abi tk kuch reply ni aya
