j7 max notification panel problem
(Topic created on: 11-18-2017 10:47 PM)
sathik
Galaxy J
j7 max sometimes notification panel not appear after reboot it will works....correct the problem
6 Comments
yeshnani
Galaxy J
evn in on max
sukh4747
Galaxy J
same yr j7max lagging and running slow
Prasenjit
Galaxy J
same here.
udayan
Galaxy J
no such prob i hv faced yet but i am facing charging issue..
admin_
Galaxy J
Thanks for being with Samsung and for sharing your concern. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
Be sure to hit ♡ when you find an answer that works for you.
NShah
Galaxy J
same in on max
