j 7 Max mobile data problem
(Topic created on: 08-05-2018 07:58 AM)
siam15
Beginner Level 3
Galaxy J
Mobile Data is turned on but symbol are not show and mobile data connection not activated. acf71165-9b56-4b5f-a7d1-5d900d43ae0c.jpg
6 Comments
Harish333
Galaxy J
thats service provider's problem
Harish333
Galaxy J
ur phone can do nothing
siam15
Beginner Level 3
Galaxy J
what can i do now?
Hemilr
Galaxy J
put sim in slot 1
admin_
Galaxy J
We do apologize for the inconvenience caused. We would like to suggest you kindly follow the below mention steps to overcome the Issue;
- Check by using any other SIM card.
- Ensure that network frequency of your device should be selected on Auto-mode.
- Menu > Settings > Connections > Mobile Networks > Network Mode > Select auto mode (GSM/WCDMA/LTE).
- Search for the Network Manually as follows:
Menu > Settings > Connections > Mobile Networks > Network Operators > Select Manual Search.
- Kindly go to settings >> General management >> Reset >> Reset network settings.
- Kindly contact the network service provider.
Be sure to hit ♡ when you find an answer that works for you. For further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
siam15
Beginner Level 3
Galaxy J
tnx for suggest
