Mobile battery problem
(Topic created on: 04-18-2021 12:30 AM)
Tinkya
Galaxy J
2 Comments
Galaxy J
Solutions ____________________
Can you ... Following those steps ..... ???
1)_ open your settings, then 'connections'> more connection settings > Nearby device sceanning > off
2)_ settings > location > improve accuracy > wifi + blutooth scenning > off
3)_ advanced features > Motions and gestures > 'lift to walk' & 'keep screen on....' > off
4)_ Battery and Device care > Battery > more battery settings > first charginf > off.... (if your phon is over heated)
5)_ Battery and device care > 3 dots > Automation > Adaptive Power saving > on ....
6)_ settings > notifications > included apps > All apps > off ..... (only turn on wats app, message, fb...)
7)_ settings> Always on Display > saw as scheduled
Follow those settings to save more battery ❤❤❤
Thank you 😁😁❤❤❤
Kawsar4s
Galaxy J
Check your bettery
