Will good lock consume more battery?
(Topic created on: 06-17-2021 03:57 PM)
RajaRP
Galaxy F
I want to install good lock modules in my f62, but I am afraid about battery drain as my device is only giving 13 hours SOT and slightly warm often. Experienced users, plz shed some light on this
6 Comments
Galaxy F
13 hr SOT is unbelievable!
Galaxy F
It won't cause any battery issue and 13hrs sot is really great..
If its getting too hot then drop feedback or else visit nearest service center and get it checked once
John J
Galaxy F
SOT for 13 hrs!!! Amazing. How long does your device battery backup last?
How many months or weeks of usage?
Did you update your device? If no, don't!
Could you share your primary use of the phone and apps?
I was able to use the device only for 20 days, given to the service center. Waiting for resolution from Samsung for last 6 days.
RajaRP
Galaxy F
Battery lasts 2 full days with around 13 hours SOT. Using since a month and running latest update only.
my use is 30% surfing, 25% YouTube, 20% Normal games, 10% voice & video calls. But with almost same usage my brother m21 mobile gives 15 hours SOT also it has 6000 mah battery and 10nm. but f62 has 7000 mah and 7nm, so I thought like 17 hours SOT.
this is a flagship chip which consumes more power for small instant boosts. If Samsung optimizes this, then we can expect even more battery life. but I don't have any expections from them
John J
Galaxy F
My usage is way lower in comparison during the 20 days. It gave just 1 day and 12 hrs.
Your device is performing better.
joshibhai
Galaxy F
Can't believe sot 13 hours..grate my f62 sot is around 8 to 9 hours
