Samsung F62 battery drain issue !!
(Topic created on: 10-20-2021 08:36 AM)
uma0901
Beginner Level 5
Galaxy F
I feel the battery consumption is high even and it drains quickly, if my phone usage is very minimal !! I bought this phone just 10 days before.. Feeling much disappointed, as I bought this phone mainly for 7000 MAH
26 Comments
Ajay_das
Galaxy F
Iam aslo using f62 Same problem facing battery drain issue, after October update camera quality gone
Ajay_das
Galaxy F
Chup shut ur mouth
Ajay_das
Galaxy F
Next update will cover
Galaxy F
Brother, after October updates most Samsung devices were performed very weird and bad.
But this problem can be solved.
I solved my "battery draining , sound playing and microphone issues and hanging issues." Through reset all settings.
"Goto setting > general management > reset > reset all settings " then restart your phone.
I'm sure it will work... 👍 try this it's very safe and good 👍Screenshot_20211015-130638_WhatsApp.jpgScreenshot_20211015-130807_WhatsApp.jpgScreenshot_20211015-130855_WhatsApp.jpgScreenshot_20211015-130935_WhatsApp.jpg
Ajay_das
Galaxy F
Galaxy F
You can try this... it will work surely... 👍
samfan91
Galaxy F
You should get at least 14 hours screen on time on normal usage, check any app running in background unnecessarily...
Ajay_das
Galaxy F
Shivam9798
Galaxy F
Sir, what do you mean by screen on time, in my f62, google wellbeing shows 6 hours usage screen on time but I did not charge my device in a day and using 100%, Sir is it normal or any fault in my device
