Help: Used fine lock to use edge lighting feature, wont turn off
(Topic created on: 06-10-2024 06:11 PM)
kamkar
Galaxy F
Im using a F23 5g and I made a mistake by using fine lock to unlock good lock modules only available to other phones. I used the edge lighting + module and now im not able to switch off this annoying notification flash. I tried disabling it, Uninstalling it, nothing is working. Any help?
The red flash keeps coming whenever I use apps with persistent notifications like spotify.
5 Comments
Umangmathur
Galaxy F
Try factory resetting your device then
kamkar
Galaxy F
Just did it, after restoring my data it started happening again, I suspect it's some hidden setting
Achu311
Galaxy F
kamkar
Galaxy F
Done that multiple times, doesnt seem to solve the issue
Imran03
Galaxy F
Go to "Edge lighting style" and set it to none.Screenshot_20240611_214644_Settings_1000081612_1718120804.pngScreenshot_20240611_214654_Settings_1000081613_1718120815.png
