Hanging, slow device, battery drain problems
(Topic created on: 10-11-2024 03:29 PM)
Parekhmeet16
Galaxy F
For Galaxy F,A,M series .
If you going throw this type of problem's (Hanging, slow device, battery drain problems )
I want to suggest that go in about phone->software information-> Google play system update-> and install the update if available.
 Why ?
because this update improve your device stability and performance and Chaeck every month because Google give update every month
The latest update from Google is September security.
And believe me this update is so Good so go and install
And one thing remember that every month you get update but don't update first check that update don't get any problem in smartphone than after you can update
7 Comments
Oldy4756
Galaxy F
Joke of the day - Update can fix thing's.
Parekhmeet16
Galaxy F
Ha samsung me fix hota he. Chinese brand me nahi hota (onepluse) 🙏
Bhargab21
Galaxy F
No i updated it doesn't fix the issue its still there. The problem is in samsung optimization of its system for the low grade processors and rams in F series.
If they are now optimizing the software then how a S series optimization will work in F series. They just ignore F series phones as they are budget friendly
Parekhmeet16
Galaxy F
Ya you are right but sometimes this software update helpful for device stability
Bhargab21
Galaxy F
You make the base first then you build a house, if the the issue is in One UI itself how a security patch or small update will fix the issue.
They need to realise this issue and give major update full optimization of the software. Stock android has better optimization than samsung. Samsung skin is very heavy on ram and eats up most of the ram storage.
Past one month im facing severe issue of lagging and heating i have to reboot the device 2 times daily everyday, tell me how is this justifiable and fair on user.1728668666741.jpg1728668666796.jpg
AnansAgrawal
Galaxy F
Hi
AnansAgrawal
Galaxy F
By
