Freez and auto restart problem
(Topic created on: 04-23-2022 12:42 AM)
sคᴅɪQʏᴛ
Galaxy F
It's been a month I purchased new f23 ,after 10 days m facing hanging problem, app are crashing ,sometime phone gets stuck or freezes and 2 to 3 times phone restarting automatically, factory reset also done  but problem not solved..very disappointed
14 Comments
Debdip_Mandal
Galaxy F
Same problem for me
cs_member8
Galaxy F
Dear Samsung member,
Kindly use a genuine Samsung charger.
Note: We always recommend using a genuine Samsung charger for charging your device.
There are two methods to disable the auto-restart function
Method 1
Please follow the below steps:
Step1: Navigate to the app's screen and tap on Settings.
Step2: Tap on General management.
Step3: Tap on Reset.
Step4: Disable Auto restart (if enabled).
Step5: Auto-restart disabled.
Step1: Go to "Settings"
Step2: Tap on "Battery and device care"
Step3: Tap on Three dots
Step4: Tap on "Automation"
Step5: Disable "Auto-restart at set times" if enabled
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback >Error report).
Warm regard,
Athuljoy
Galaxy F
Bro please 🙏 help
me I have same problem in f23 how to fix it I have went to service center they installed new software but auto restart problem
Is not gone
irs100
Galaxy F
Same problem
I 3 times visited zervice center
Galaxy F
After recent update I inserted memory card till now working fine..
