Battery problem
(Topic created on: 01-11-2022 05:11 PM)
hrsil
Galaxy F
It has 7000mah battery but not worth because it decrease fast.
4 Comments
hrsil
Galaxy F
Galaxy f 62
Div001
Galaxy F
Optimize your phone to save battery...just search battery saving tips ...and u will find 100s of posts
f62_CA
Expert Level 3
Galaxy F
Exynos.......
cs-member13
Expert Level 4
Galaxy F
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
