Rajesh_joshi
11-24-2022 08:46 AM in
Galaxy FMy samsung f62 after one UI 5.0 update slow warking many time hang issue show and bettry drain fast . I'm already 2 times phone resat but not solve problems
6 Comments
Ajay_das
11-25-2022 12:07 AM in
Galaxy F
Yes battery drain issue more
Ajay_das
11-25-2022 12:08 AM in
Galaxy F
Waste drain issue more
irfansayyed0786
11-25-2022 11:56 PM in
Galaxy F
Bro cache partition kar lo recovery mode me jakar
Ajay_das
12-03-2022 12:06 AM in
Galaxy F
Same problem facing battery drain issue F62
Ajay_das
12-03-2022 12:07 AM in
Galaxy F
6hours only
N_D
2 hours ago in
Galaxy F
Try this — it helped me get stable performance on F62 without issues:
1. Always use Power Saving Mode – keeps background activity and CPU usage under control.
2. Charge overnight only when temperature is low – avoid charging in hot environments.
3. Go to Device Care > Storage, let it load, and clear cache files. If that doesn’t appear, manually clear cache for each app.
4. Set auto reboot daily from Device Care settings – improves long-term performance.
5. After 300–400 charge cycles, battery health naturally drops to 80% – heating and reduced performance can be expected, especially after 1–2 years.
6. For heating and lag, go to Settings > Apps > [app name] > Battery > Restrict background usage for apps that don't need to run constantly.
7. Don’t use phone while charging. Remove the case, don’t place it on soft surfaces like pillows, and avoid using it under load when plugged in.
8. Turn off Auto Sync, WiFi, Bluetooth, and GPS when not needed.
9. Disable or uninstall unnecessary Samsung bloatware – even system apps can be disabled if not used.
10. If the camera lags, go to the camera app settings and clear app data – it resets the camera without deleting your photos.
If this helps the please select helpful of as solution on this comment
