front camera issue of c9 pro
(Topic created on: 12-15-2017 06:57 PM)
akashakki
Galaxy C
I'm having a problem while taking pics on c9 pro front camera... The pic get blur if the person is standing beside he gets blur in the pic... Plzz do reply if any one facing the same problem and plzz samsung dont tell check camera pixel and reset camera and update via fota . reply a satisfied answer
admin_
Galaxy C
Thanks for being with Samsung and for sharing your concern. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
Be sure to hit ♡ when you find an answer that works for you.
