battery problem
(Topic created on: 02-27-2020 08:24 PM)
Saih75
With battery % of 85 it shows battery life time as 8h 30m, does this indicate an issue with my battery ,why does my battery drain so fast ?
3 Comments
døpedædə
no problem bro...it only shows your estimated battery backup according to your usage patterns...nd it vary for person to person...for my case I dont use my phone much nd the estimated battery is showing approx 15 hours with 84% battery...so dont bother...feel free to use your device...✌✌
Saih75
thank you bro👍
raju-83
Don't worry. It is not a problem. Battery draining depends upon your background apps
